Simple table on Map Series layout
921
10-22-2019 07:38 AM
deleted-user-p7EuYBBC3iNj
I am trying to include a simple table on a map layout within a map series. The table should be very simple as the map series contains only one feature per map and I would like the table to show only two columns. Column one is the alias of the fields I want to include and column two is the attribute for that feature held within the table. I assume this is fairly easy to do but I just can't work out how! Thank you for any help.
KoryKramer
Esri Community Moderator
Take a look at this help topic, and specifically the map series section: Add and modify table frames—Layouts | ArcGIS Desktop
