Simple table in Label Expression
3205
03-21-2023 01:08 PM
EmmaO
I want to create simple tables in my labels. I thought that using python and pandas dataframe might work, but although the expression verifies as valid, no labels appear on my map. Is there a different way to accomplish this either in Python or a different language? I am using ArcPro 3.1. Thanks
JohannesLindner
Labels only show strings, s you have to return a string.
I can' test right now, maybe it works with the DataFrame method:
def FindLabel():
    table = getTable()
    return table.to_string()
If it doesn't, you can try constructing it yourself (untested):
def FindLabel():
    d = {"DATE": ["Fall 2018", "Spring 2019"], "RESULTS": [7.1, 8.4]}
    # get the column names and the max row count
    columns = k in d.keys()
    num_rows = max([len(d[c]) for c in columns])
    # header in bold
    rows = [
        "\t".join([f"<BOL>{c}</BOL>" for c in columns]),
    # append the values
    for r in range(num_rows):
        row = []
        for c in columns:
            # get the value of current r and c, or default empty string
            try:
                row.append(str(d[c][r]))
            except IndexError:
                row.append(" ")
        rows.append("\t".join(row))
    # concatenate the rows with line breaks
    return "\n".join(rows)
Have a great day!
Johannes
JohannesLindner
def FindLabel():
    table = getTable()
def FindLabel():
    # header in bold
    rows = [
    # append the values
        row = []
        for c in columns:
            try:
            except IndexError:
                row.append(" ")
Have a great day!
Johannes
EmmaO
table.to_string() works! Thank you
JeffreyFitzgibbons
Can you post a screenshot for how the final product looks? I tried in arcgis pro 2.9.0 but its just text separated by spaces. Thanks.
EmmaO
Here is what it looks like in 3.1. I actually spoke a little too soon. I thought that using the methods here I would be able to format it how I wanted, but having played around, I haven't been able to do so. It also would be nice if there were lines to format the table, but I'm not sure if that's possible.
