Should I snap to network in the network analysis
2696
07-07-2021 03:47 PM
zhongying_gan
Hello. I'm using the Closest Facility tool and OD Cost Matrix tool under network analyst in ArcGIS Pro. I use my own local network dataset. Do you recommend me checking "snap to network" when I import facilities/incidents/origins/destinations? What difference will it make if I don't check it? Thank you.
DanPatterson
MVP Esteemed Contributor
Add Locations (Network Analyst)—ArcGIS Pro | Documentation
Don't want to miss origins or destinations if the tolerance isn't close enought
... sort of retired...
DanPatterson
