Ship Detection Using ArcGIS deep learning
3500
6
10-25-2023 06:00 AM
Aminu
I currently have ArcGIS pro version 3.1.3, and followed the steps at esri and github and installed the deep learning frame work v3.1 for Arcgis pro. I then proceeded to download the SAR image of the harbor of Aberdeen from copernicus. I then proceeded to use the Arcgis model to detect ship from the SAR image as show on the ArcGis website (see screenshots), However I keep receiving this error code: "
  File "C:\Users\23470\Documents\ArcGIS\Projects\MyProject23\DetectShipsFromSAR.py", line 64, in <module>
    out_raster = arcpy.management.Clip(in_raster, "#", "#", in_mask, "65536", "ClippingGeometry", "NO_MAINTAIN_EXTENT")
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 20983, in Clip
    raise e
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\management.py", line 20980, in Clip
    retval = convertArcObjectToPythonObject(gp.Clip_management(*gp_fixargs((in_raster, rectangle, out_raster, in_template_dataset, nodata_value, clipping_geometry, maintain_clipping_extent), True)))
  File "C:\Program Files\ArcGIS\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda>
    return lambda *args: val(*gp_fixargs(args, True))
arcgisscripting.ExecuteError: ERROR 001566: Failed to create raster dataset. The reason could be: The clip feature is outside the raster extent.ERROR 001566: Failed to create raster dataset. The reason could be: The clip feature is outside the raster extent.
Failed to execute (Clip).
Failed script Detect Ships using SAR data...
Failed to execute (DetectShipsUsingSARData).
Failed at Wednesday, 25 October 2023 12:44:31 (Elapsed Time: 5.26 seconds)
Here are screen shots, Kindly assist, I wan t to detect ships at the harbor of Aberdeen
1.png2.png3.png4.png5.png6.png7.png9.png10.png11.png12.png14.png15.png16.png17.png18.png19.png
Robert_LeClair
Esri Esteemed Contributor
I think you may be missing a parameter - the Input Water polygon (listed as AOI) in the documents.  I believe this serves as the clipping polygon for the deep learning package.  I'd recommend creating an AOI polygon feature class for your area of interest and run the GP tool again.
Aminu
I really don't know how to do that, how can I create an AOI?
Robert_LeClair
First, you will need to create a polygon feature class in your project geodatabase.  Then you need to digitize/create a new polygon feature in your polygon feature class.  Lastly save the edit session and then use that newly created feature as input for the geoprocessing tool.  If you've never done this before, there's a quick start tutorial here that follows the editing workflow for creating a point - just substitute the polygon concept for the point concept.
Aminu
Thanks, I did follow the tutorial you provided (see screenshot), unfortunately I still get this error code:
"Detect Ships using SAR data
Parameters
Input Raster C:\Users\23470\Desktop\ArcGIswork\Images\S1A_IW_SLC__1SDV_20230916T063025_20230916T063052_050349_060FCD_0481.SAFE\measurement\s1a-iw2-slc-vv-20230916t063027-20230916t063052-050349-060fcd-005.tiff
Output Detected Ships C:\Users\23470\Documents\ArcGIS\Projects\MyProject25\MyProject25.gdb\s1aiw2slcvv20230916t06302720230916t063052050349060fcd005_DetectShipsUsingSARData
Input Water Polygon Aberdeen Harbor Latest 2
Model Definition C:\Users\23470\Desktop\ArcGIswork\SARShipDetection.dlpk
Model Arguments padding 56;batch_size 4;threshold 0.4;tile_size 512
Non Maximum Suppression false
Confidence Score Field Confidence
Class Value Field Class
Maximum Overlap Ratio 0.2
Processor Type CPU
GPU ID 0
Cell Size 6.66299810375457E-05
previous_raster C:\Users\23470\Desktop\ArcGIswork\Images\S1A_IW_SLC__1SDV_20230916T063025_20230916T063052_050349_060FCD_0481.SAFE\measurement\s1a-iw2-slc-vv-20230916t063027-20230916t063052-050349-060fcd-005.tiff
Messages
Start Time: Thursday, 26 October 2023 13:09:16
Clipping the raster...
File "C:\Users\23470\Documents\ArcGIS\Projects\MyProject25\DetectShipsFromSAR.py", line 64, in <module>
raise e
arcgisscripting.ExecuteError: ERROR 000446: Output file format with specified pixel type or number of bands or colormap is not supported. Refer to the 'Technical specifications for raster dataset formats' help section in Desktop Help.
The table was not found. [s1aiw2slcvv20230916t063_Clip]
Failed at Thursday, 26 October 2023 13:09:22 (Elapsed Time: 5.81 seconds)"
Added an input water polygonAdded an input water polygon
Any idea?
Robert_LeClair
Thank you for the screen grab and the error messages.  One thing that stands out is your out put raster dataset - C:\Users\23470\Documents\ArcGIS\Projects\MyProject25\MyProject25.gdb\s1aiw2slcvv20230916t06302720230916t063052050349060fcd005_DetectShipsUsingSARData - has a SUPER long name!  That could be the issue.  I would change the output name to be C:\Users\23470\Documents\ArcGIS\Projects\MyProject25\MyProject25.gdb\DetectedShipsUsingSARData or something even shorter.  Run the tool again.  What is the output or error message?
ShivaniPathak
Hey Aminu,
Were you able to run the Detect Ships using SAR data tool?
The tool ran successfully at my end.
