Sharing Web Layer: Error 00062
5237
10-23-2020 09:10 AM
SteveCole
Honored Contributor
I cannot find any more information about this error and what to do about it. Backstory:
In ArcGIS Pro, I have a very simple map I imported from Arcmap: one point layer located in SDE "A" and one table located in SDE "B". When I attempt to use the Share Layer As Web layer Tool to publish this to our Portal, the Analyze button reports back Error 00062: "Map contains data that does not use the same connection to an enterprise database (Web Feature Layer)".
So- what do I do? I'm using ArcGIS Pro 2.4.1
Steve
JonahLay
Hi Steve,
In addition to Robert's response, you can address this error by following the solutions listed here: 00062: Map contains data that does not use the same connection to an enterprise geodatabase
Best,
Jonah
Robert_LeClair
Esri Esteemed Contributor
It seems AGP is trying to publish both the spatial and non-spatial table in one GP operation.  What you could do is right-click on the point layer and select Sharing-Share as Web Layer.  This will share ONLY the selected layer in your Contents Pane.  Repeat for the table.  Then both layers are published as individual hosted feature layers.  Good luck!
JonahLay
Hi Steve,
Best,
Jonah
SteveCole
Honored Contributor
Thanks, guys. I marked Jonah's response as correct since his link explicitly states why this error was happening. I realized after posting that I had dealt with this before and my workaround was to take the table, convert it to an Excel file, and then upload that into Portal and turn it into a service. That's what I'll be doing here as well.
Thanks again.
Steve
RoggerCorrea
Is ESRI planning to allow publishing services with multiple GDB sources? so far any of the solutions proposed do not work for my case.
Thanks
