I have a feature layer symbolized using Domains, and it displays correctly in both ArcGIS Pro and ArcGIS Online, with the symbology showing up as expected in the layers and Legend. However, when I use the edit tool, the layer displays the coded values of the Domains instead of their descriptions. This is problematic, especially since the plan is to use the Web Map in an Experience Builder app for data collection, where users need to see the descriptions, not the codes. Is there a way to adjust this so that the descriptions are visible during editing?
@NakiddeLightonCRP What do you mean by "edit tool"? Somewhere in ArcGIS Pro or do you mean in the ArcGIS Online map viewer?
Edit in ArcGIS Online
On the right is when I open the edit tool
@Scott_Harris Have you found a solution to my problem?
@NakiddeLightonCRP Sorry I don't have an answer. I suggest contacting Esri Technical Support and/or asking your question in the ArcGIS Online place https://community.esri.com/t5/arcgis-online/ct-p/arcgis-online
