Share a project
1586
09-14-2023 02:16 AM
lmatteo
Hello,
I'm using an enterprise database with some of its layers used inside a project.
I usually share theese layers with the sharing option "project package" so, all the styles (and some other things) are also shared.
Anyway, I have some field of some layers that I do not want to share. but also, some other informations that I don't want to share (from other maps inside the same project). The second option can be easilly solved with the sharing option "layers package", but still, I can not filter some fields.
Is there any possibility of filtering fields for layers that are shared ?
JonEmch
Hello @lmatteo, thank you for posting!
   I've researched this and found some interesting information. I did want to confirm that you are using ArcGIS Pro 3.x, is that correct?
   Looking at our documentation here Package Layer (Data Management).
   I see that we have the Schema Only option, which would be great if you do not need to share the data. Please let me know if this helps at all!
Keep on keeping on!
lmatteo
Thanks for your answer, anyway yes, we have to share the data from the feature classes 😕
I will take a look at this function,
