Setting width of Column in a Table Frame by giving user defined values
719
04-21-2022 05:20 AM
by Anonymous User
Not applicable
I'm trying to set the width of a column in a Table Frame using ArcGIS Pro .NET SDK but to do so currently I'm using the below code for setting the width automatically.
TableFrame newtableframe = LayoutElementFactory.Instance.CreateTableFrame(layout, rec_env, mf, lyr, SelectedKegColumns);
var def = newtableframe.GetDefinition() as CIMTableFrame;
def.FittingStrategy = TableFrameFittingStrategy.AdjustColumns;
def.FittingStrategy = TableFrameFittingStrategy.AdjustColumnsAndSize;
def.FittingStrategy = TableFrameFittingStrategy.AdjustFrame;
def.FittingStrategy = TableFrameFittingStrategy.AdjustSize;
def.FillingStrategy = TableFrameFillingStrategy.ShowAllRows;
However I'm looking to set the width to a user defined value for eg: 20mm, 30mm etc. Is it possible through the API?
Thanks in advance!
