Setting Source URI on PictureElement not working
931
02-17-2023 06:59 AM
marco_vertigis
Hi there,
Today I was trying to programatically set the source uri (local filepath) of a ArcGIS.Desktop.Layouts.PictureElement with the provided SetSourcePath() SDK method. Unfortunately this seems to have no effect at all. The PictureElement on the layout remains empty without any feedback.
After I looked at the implementation of the SetSourcePath() Method, I could implement it by myself.
private void SetPictureSource(string uri)
    // SDK call '_pictureElement.SetSourcePath(uri)' not working
    _pictureElement.SetSourcePath(uri);
    // manually setting source url over cim definition working
    QueuedTask.Run(() =>
        var definition = _pictureElement.GetDefinition();
        if (definition is CIMGraphicElement graphicElement &&
            graphicElement.Graphic is CIMPictureGraphic pictureGraphic)
            pictureGraphic.SourceURL = uri;
            graphicElement.Graphic = pictureGraphic;
            _pictureElement.SetDefinition(graphicElement);
The SDK implementation almost looks the same but its setting PictureURL instead of SourceURL.
// SDK Implementation
public void SetSourcePath(string URI)
    LayoutUtil.EnsureWorkerThread();
    string fullPath = Path.GetFullPath(URI);
    if (!File.Exists(fullPath))
        throw new Exception("Invalid Picture path");
    ElementUtil.UpdateElement(_container, base.Name, Resources.OperationUpdatePictures, delegate (CIMElement cimElement)
        CIMPictureGraphic cIMPictureGraphic = (cimElement as
        CIMGraphicElement).Graphic as CIMPictureGraphic;
        if (cIMPictureGraphic != null)
             cIMPictureGraphic.PictureURL = fullPath;
Is this a SDK Bug or do I use the method the wrong way? Would appreciate any response.
