Set default raster NoData value for project, or change NoData in batch
3653
10-04-2022 04:27 PM
Labels (2)
ElijahMlawsky
I would like all geotiffs generated in my current project to have a default NoData value of -9999 instead of -3.40282346639e+038. If there is no way to set this value as a project default or environment setting, then what would be the best way to change the value as a batch operation on many rasters at once?
In ArcMap 10.7, I was able batch the "Copy Raster" tool and set the NoData value from there. However, in ArcGIS Pro, the Batch Copy Raster tool won't let me input a custom value in the NoData field (after typing in -9999, it snaps back to "3.4e+38"). I have not tried saving the batch tool and overwriting the value in a Python command yet, but would prefer a GUI solution to instruct other users on.
Any ideas? Thanks.
DanPatterson
MVP Esteemed Contributor
Are they all the same type of raster? (eg 16, 32 bit) or are there some differences?
I had no problem with regular rasters but I didn't try geotiffs.  But try -9999. with the decimal point since your original nodata value is for floating point rasters
... sort of retired...
ElijahMlawsky
I did try it with the decimal, and they should be exactly the same type in this instance…
