Set default raster NoData value for project, or change NoData in batch
3658
10-04-2022 04:27 PM
ElijahMlawsky
I would like all geotiffs generated in my current project to have a default NoData value of -9999 instead of -3.40282346639e+038. If there is no way to set this value as a project default or environment setting, then what would be the best way to change the value as a batch operation on many rasters at once?
In ArcMap 10.7, I was able batch the "Copy Raster" tool and set the NoData value from there. However, in ArcGIS Pro, the Batch Copy Raster tool won't let me input a custom value in the NoData field (after typing in -9999, it snaps back to "3.4e+38"). I have not tried saving the batch tool and overwriting the value in a Python command yet, but would prefer a GUI solution to instruct other users on.
Any ideas? Thanks.
DanPatterson
Are they all the same type of raster? (eg 16, 32 bit) or are there some differences?
I had no problem with regular rasters but I didn't try geotiffs.  But try -9999. with the decimal point since your original nodata value is for floating point rasters
... sort of retired...
ElijahMlawsky
I did try it with the decimal, and they should be exactly the same type in this instance…
