Set default projection when creating feature classes
1295
07-12-2022 01:28 PM
Bud
Legendary Contributor
Is there a way to set a default projection when creating new feature classes? (enterprise GDB)
100.0% of our feature classes are NAD83 UTM 17N. I never need to create a FC with a different projection. So it would be nice if I could set a default.
I create projects/maps from scratch, without any default layers, so I don't think Pro could grab the projection from any existing info in the project/map.
DanPatterson
MVP Esteemed Contributor
If you had a template featureclass you could do default fields and spatial reference as well.
Create Feature Class (Data Management)—ArcGIS Pro | Documentation
I use a default projection for my project, and its maps
Then when I create a featureclass, I select the coordinate system of the map
I suppose you could make a project template from there
... sort of retired...
RhettZufelt
MVP Notable Contributor
If you create a Feature Dataset in your UTM, any FC's added to that FD will have that spatial reference system, even if you leave it blank in the Create Feature Class tool.
R_
