arcgis.learn.prepare_data() not working with RCNN Masks generated from ArcGIS 3.0
714
07-13-2022 08:04 AM
JamesPaskett
ArcGIS Pro 3.0
ArcGIS Python 2.0.1
DeepLearning Libraries 3.0
I am trying to run arcgis.learn.prepare_data() on an exported RCNN mask dataset. Dataset was generated from ArcGIS 3.0. I think there is an in compatability with the .emd file for RCNN mask in 3.0?
Error:
  File "c:\users\16142\appdata\local\programs\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 308, in execute
    data_bunch = prepare_data(in_folders, working_dir=out_folder, **prepare_data_kwargs)
  File "C:\Users\16142\AppData\Local\ESRI\conda\envs\deep-learning-py3\Lib\site-packages\arcgis\learn\_data.py", line 1822, in prepare_data
    ArcGISInstanceSegmentationItemList.from_folder(path / "images")
  File "C:\Users\16142\AppData\Local\ESRI\conda\envs\deep-learning-py3\Lib\site-packages\fastai\data_block.py", line 479, in _inner
    self.train = ft(*args, from_item_lists=True, **kwargs)
  File "C:\Users\16142\AppData\Local\ESRI\conda\envs\deep-learning-py3\Lib\site-packages\fastai\data_block.py", line 303, in label_from_func
    return self._label_from_list([func(o) for o in self.items], label_cls=label_cls, **kwargs)
  File "C:\Users\16142\AppData\Local\ESRI\conda\envs\deep-learning-py3\Lib\site-packages\fastai\data_block.py", line 279, in _label_from_list
    y = label_cls(labels, path=self.path, **kwargs)
  File "C:\Users\16142\AppData\Local\ESRI\conda\envs\deep-learning-py3\Lib\site-packages\arcgis\learn\models\_maskrcnn_utils.py", line 97, in __init__
    if is_no_color(list(color_mapping.values())):
  File "C:\Users\16142\AppData\Local\ESRI\conda\envs\deep-learning-py3\Lib\site-packages\arcgis\learn\models\_maskrcnn_utils.py", line 70, in is_no_color
    return (np.array(color_mapping) == [-1.0, -1.0, -1.0]).any()
AttributeError: 'bool' object has no attribute 'any'
During handling of the above exception, another exception occurred:
  File "c:\users\16142\appdata\local\programs\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 390, in <module>
    execute()
  File "c:\users\16142\appdata\local\programs\arcgis\pro\Resources\ArcToolbox\toolboxes\Image Analyst Tools.tbx\TrainDeepLearningModel.tool\tool.script.execute.py", line 384, in execute
    del data_bunch
UnboundLocalError: local variable 'data_bunch' referenced before assignment
