Set default Portal connections for ArcPro users
1860
01-29-2025 08:52 AM
MichaelJenkins
Our organization is intersted in managing some default settings for our users so everyone can have same starting point.  One of the things we woudl liek to set for the user is the Portal connections to our ArcGIS Online organization and our on-prem ArcGIS Enterprise Portals.
We've looked closely at the  Manage application settings—ArcGIS Pro | Documentation
but haven't found anything about setting the Portal connection URLs.  Is there a way to do this?  If not, are there any less than ideal alternatives?  For example, can we provide Portal connections in a custom Project Template?
GISP
BillFox
MVP Notable Contributor
BillFox
MichaelJenkins
Ooh, good find!  We install ArcPro on user machines via Microsoft SCCM.  Any idea if that is considered a silent install?
GISP
MichaelJenkins
I'm marking your answer as a solution.   Still no word from our SCCM people as to if it will work for us or not, but it is valid answer.  Thanks!
GISP
nieltown
Is there a way to do this after installation? That is, are additions to the default portal list scriptable after installation?
