Set default label parser
1946
05-08-2019 09:35 AM
MattWilkie1
How can I set the default label expression parser in Pro? Either globally or per project.
Thanks.
Tags (3)
KoryKramer
Esri Community Moderator
Do you mean the Language:
There is no setting for that AFAIK, either per project or globally.
MattWilkie1
Yes I mean language. Too bad there's no preference for it. Kinda annoying to flip the button and select every single time.
KoryKramer
I didn't see anything already on ArcGIS Ideas‌ related to this.  Maybe worth posting.
MattWilkie1
KoryKramer
Yup - I ran into that one when searching for what you're currently requesting.  So in Pro 2.4, there will be access to make these changes through Python.  But that doesn't set the default, and you wouldn't want to use Python to change that every time as opposed to just using the drop-down
