I have an instance of ArcGIS Server running as a standalone installation. I am trying to setup ArcGIS Pro to be able to publish services to the server, and I am able to connect to it from ArcGIS Pro but only with user privileges, not publisher or administrator which are required for the publishing I need to do.
Here is a screenshot of the catalog section showing that the connection is present (it has detected an empty folder I added, so there is evident communication):
When I right click on the server and open the properties menu I have the following:
The publisher and administrator options are available. So I click ok and get this next message:
This is strange because there is certainly a connection, and I am also able to log into the ArcGIS Server Manager directly from a browser as shown here:
I have also tried creating another administrator level user and logging in as that user, but the same problem occurs.
More info:
- This is a standalone instance of ArcGIS Server that is not federated with portal.
- ArcGIS Server version 11.1
- ArcGIS Pro version 3.13
Does anyone have any thoughts or suggestions on what I might try to enable publishing in this manner? I have been struggling with this. Any ideas are greatly appreciated.
Did you get this resolved? I'm having the same issue.
Same issue from ArcGis Pro 3.4 to Server 10.9
looking for solution
