Server connection type cannot be set to administrator or publisher
2355
08-26-2023 04:57 AM
drist1
I have an instance of ArcGIS Server running as a standalone installation. I am trying to setup ArcGIS Pro to be able to publish services to the server, and I am able to connect to it from ArcGIS Pro but only with user privileges, not publisher or administrator which are required for the publishing I need to do.
Here is a screenshot of the catalog section showing that the connection is present (it has detected an empty folder I added, so there is evident communication):
When I right click on the server and open the properties menu I have the following:
The publisher and administrator options are available. So I click ok and get this next message:
This is strange because there is certainly a connection, and I am also able to log into the ArcGIS Server Manager directly from a browser as shown here:
I have also tried creating another administrator level user and logging in as that user, but the same problem occurs.
More info:
- This is a standalone instance of ArcGIS Server that is not federated with portal.
- ArcGIS Server version 11.1
- ArcGIS Pro version 3.13
Does anyone have any thoughts or suggestions on what I might try to enable publishing in this manner? I have been struggling with this. Any ideas are greatly appreciated.
Kristen_KGS
Did you get this resolved? I'm having the same issue.
GregMiddleton
Same issue from ArcGis Pro 3.4 to Server 10.9
looking for solution
