Separate Numbers from Text
2401
7
05-08-2024 02:40 PM
ChrisMacNeillNCFPD
Hey team, I have an address field with the entire address in one cell, which looks like this one for example "15775 W California AVE ".  I'm trying to pull out just the number portion so I can join it to another table.  The format is inconsistent and some are 3 digits and some are 5 so its giving me more trouble than I was anticipating.  Anyone know of a way to do this with a calculated field?
DanPatterson
MVP Esteemed Contributor
a = "15775 W California AVE"
"".join([i for i in a.split(" ")[0] if i.isdigit])
'15775'  # for text output
int("".join([i for i in a.split(" ")[0] if i.isdigit]))
15775 # for integer output
... sort of retired...
DanPatterson
ChrisMacNeillNCFPD
Awesome, thank you!
ChrisMacNeillNCFPD
Would I replace the actual address in line 1 with the field name? So in this case a = !Address!
DanPatterson
Yes, for field calculations.  In my example  a  would be replaced by !YourFieldName! ( !Address!, if that is the fieldname)
JasonBagwell1
Hi Chris,
I've used this Python script/calculation before with success.
!YourField!.split(' ')[0]
This separates the field at the first space, returning just the address number.
DanPatterson
split works unless the number has a letter attached like, hence the rest of the code
15775a
MeKohler
How would you start this from the right side?
Thanks.
