selecting maximum value of an attribute table to create a layer
6054
6
10-08-2021 11:34 AM
SalvoA
I would create an event layer  in ArcMap selecting values from a table  with a sql query.
In particular I would like to select the row with the maximum value of an attribute, so
I thinked a sql query as:
RealPosition.Easting = ( SELECT MAX ( RealPosition.Easting ) FROM RealPosition )
where RealPosition is the table and Easting is the attributo but the select tool but it says an invalid sql expression was used.
How can I solve?
Thanks.
JayantaPoddar
In ArcMap, I can open the table > Table Options > Select By Attributes.
Use a similar expression
FIELD_NAME = (SELECT MAX(FIELD_NAME) FROM TABLE_NAME)
Try
Easting = (SELECT MAX(Easting) FROM RealPosition)
Think Location
SalvoA
Thanks for your replay.It's work for a simple table, but I have a table joined with another.Could this be the problem?
JayantaPoddar
Oh!
A similar expression (to your original expression) works for me. My tables are stored in a File Geodatabase.
Think Location
SalvoA
Thanks.
The problem is that I used a "join" where a "relate" was needed, so it didn't work.
I have another problem:
I want select max value between rows that have an attribute equal to a value(for example Unit = 'TAB1')Is it possible to do "sequential sql queries "?
Thanks.
JoshuaBixby
MVP Esteemed Contributor
I think I understand the question, but an example using some sample data would be most helpful.  If you want to select the maximum value in a group:
IDValue
A5
A2
A10
B3
C4
C6
It can be possible, but it depends on the back-end data source because SQL support is based on the data source.
SalvoA
Yes, your example is correct.
what kind of database should I use?
Thanks.
