Select the network diagram's reduced lines from the map
1049
04-03-2023 02:28 AM
tarekgalal
I need to select the network diagram's reduced lines from the map to calculate their length.
A similar build-in tool is network diagram (Apply To Maps), but I need to get them from the Back-end to do some additional operations
A similar build-in feature is network diagram's (Apply To Maps)
AnneYvonneBlin
Hi @tarekgalal
Using ArcGIS Pro SDK for .NET, you must work with the FindNetworkRowQuery class (https://pro.arcgis.com/en/pro-app/latest/sdk/api-reference/topic75506.html) with the AddAggregations property at True to get all the network features/objects under a network diagram reduced line (or a network diagram collapsed point).
Hopping this helps
Anne-Yvonne
AnneYvonneBlin
Hi @tarekgalal
Hopping this helps
Anne-Yvonne
