Select related posts?
1021
07-09-2019 05:11 AM
Axelvon_Matern
Hi!
1. I have a layer with building data (SHMBuildingArea). Related to this layer is a Standalone table with building use (SHMBuiUse).
I need to change a couple of thousands of building use. But can not find a way to do this.
2. If I try to make the change in the parent table it wont let me. Get error code "000308 Invalide field type" when doning calculation and cant edit the record directly in the table.
3. I can do the changes via the attribute window. But it is a very manual, time consuming task.
4. When I click the button "Related table" I get no hit.
Axelvon_Matern
Solved!
I removed all related tables and added them right back... voilá... all related tables neatly in the attributes window! Happy, happy! No idea why they didnt show to begin with tho.
Axelvon_Matern
Solved!
