Select Feature By Location - Points Not on Line Getting Selected
2199
03-08-2024 05:56 AM
EvanMyers1
I have found an instance where the Select Feature By Location, using select by intersect with 0 distance, is selecting features when they shouldn't.  See below, notice how close I am:
This is creating problems in our database where we need pipes split at valves and fittings.  In this case, it skipped a split here.   So, even though the select by location says it intersects, the Split By Feature point tool doesn't think so.
Is this a bug?
RhettZufelt
MVP Notable Contributor
Would have to test on copy first, but I believe if you run a Snap on the valves and fittings (to the lines) with real small tolerance, it should move them over so that the Split By Feature tool would think so.  Unless, of course, the snap tool has issues with XY tolerance as well.
R_
MErikReedAugusta
MVP Regular Contributor
I think this is an issue of the XY tolerance settings in your map.  If you're that close, then all of ArcGIS' tools will consider those two features to be functionally coincident.
https://pro.arcgis.com/en/pro-app/3.1/tool-reference/environment-settings/xy-tolerance.htm#:~:text=F....
M Reed
"The pessimist may be right oftener than the optimist, but the optimist has more fun, and neither can stop the march of events anyhow." — Lazarus Long, in Time Enough for Love, by Robert A. Heinlein
If this post or another helped you out, please consider giving the post(s) a Kudo or marking them as the Solution. ESRI Staff use both of these features to help keep track of posts on these forums.
RhettZufelt
R_
EvanMyers1
I just ran Snap and it looks like it worked.  I never thought of the XY tolerance for my map so that is something to keep in mind.
Thanks!
