select column
3004
04-04-2023 06:59 AM
temprobertcottreau131313
Can someone please explain how to select a single column in an attribute table so that I can copy these values into an Excel sheet.  Not the whole table, just a single column.  Without copying the column headers.
It seems I've never actually done this because nothing I'm doing is working.
Thanks.
SLouq
by MVP Alum
Right click on the Column Heading and Try using summarize
this will create another table.  I just want to copy and paste the column
SLouq
by MVP Alum
I don't know of any way to right click on an attribute table heading in ArcGIS Pro and have the option to Copy the attributes. I've always used Summarize, which creates a .dbf table with the column(s) I want and then copied the column from the .dbf table into the Excel document I wanted it.
turns out that the way to do this is to copy everything into a blank Excel sheet and then copy that single column of data from there to paste into the Excel sheet I want.
Thanks for your thoughts.
