Select by Attributes: AND...AND
1463
09-30-2022 05:44 AM
M_ST
Hi, I would like to run a query that includes multiple codes of a field, like Selection: Where clc_18 is equal to (Number) AND clc_18 is equal to (Number) ....But no results were found. What did I do wrong?
Luke_Pinner
MVP Regular Contributor
Your query is requesting rows where each entry in the clc_18 field is both one value and a different value at the same time.  That will always return no rows.
Use OR instead of AND, e.g clc_18 = Number OR clc_18 = Another Number
Or use the IN operator, e.g clc_18 IN (Number, Another Number, Some Other Number)
Luke_Pinner
M_ST
Thanks! It works without problems. 😁✌️
