Screen keeps switching between everything greyed out and everything looking okay
84
Thursday
OverstoryGIS
For some context, we recently moved to store all our data on a NAS. After having a lot of performance issues, they did some upgrades to improve the connection between the desktop (or hard drive?) and the NAS to help with that. I don't know if what's happening now is related, because it seems like arc is just glitching, but including in case it's helpful. The arc project itself is on the desktop, but the data is on the NAS. *Updated to add that I tested it with everything (project and data) on the desktop and everything on the NAS. Things sped up a tiny bit with both project and data on the NAS, but not by much and it didn't improve this issue.*
Today, anytime I click anything to do with a geodatabase from the catalog pane or within a map's content pane, arcgis pro (3.7.1), everything greys out. I can't save or open a project, all the tools in the ribbon go grey. The map itself loads, I just can't change anything in its contents. It will stay greyed out for several minutes, look like it is okay, and then I'll try to do something in the program again and it will grey once more. I tried restarting the desktop, but that didn't help the problem. Sometimes it will flip back and forth pretty rapidly without me having clicked anything. While it's greyed out, or deciding if it wants to grey out again, I can't do anything in the program.
Here's a screenshot of what I mean:
Any ideas or help for what's going on? Has this happened to others?
Thank you!
Laura
by MVP Regular Contributor
Sometimes clearing my ArcPro cache fixes some random problems I have. esri support has recommended this to me in the past as well.
OverstoryGIS
thank you! I'm not sure who I've angered, but I did that and now everything is really broken. It's been spinning for several minutes just trying to load the map when that was the one thing it did before 🤣😅
but i do appreciate your effort and taking the time to respond.
Laura
oh no!!!@ hmmm have you tried - making a copy of one of the GDBs that is currently on the NAS and put the copy directly on your desktop. then assess the new gdb copy from Pro? does that work? maybe its a connection issue??
