Scheamatics In ArcGIS Pro 2.1
3157
6
03-12-2018 06:30 AM
RajeshMane
We are planning to upgrade our desktop system ArcGIS 9.3.1 to ArcGIS pro. On schematics front , We have huge configuration and diagrams are available to migrate to new version of ArcSchematics.
I haven't heard anything on Schematics and Pro. the extension which is available with ArcMap is going to made compatible with ArcGIS Pro 2.1 ?. ArcGIS pro will be able to generate new diagrams based on new configuration ?
 Any feedback would be greatly appreciated.
Tags (1)
DanPatterson_Retired
Tools that are not available in PRO
 http://pro.arcgis.com/en/pro-app/tool-reference/appendices/unavailable-tools.htm
Schematics is not offered
There is a blog on the scheduled timelines as to whether it is in the short term or long term.
https://community.esri.com/community/gis/applications/arcgis-pro/blog/2018/02/02/arcgis-pro-roadmap
KoryKramer
Esri Esteemed Contributor
RajeshMane‌ Are your schematic diagrams built for utility data or network dataset (transportation) data?
RajeshMane3
Apologies for late reply.
My schematics which is built on network data set(Geometric Network) ArcGIS 9.3.1
Do we have anything that directly support older Schematics in ArcGIS pro?
RajeshMane3
Its on Telecom Fiber network model, which has geometric network
RickAnderson
The stand-alone arcgis schematics extension is not available for Pro.  The new version of schematics, called Network Diagrams, is available in pro though and won't be available in ArcMap.  Network Diagrams are built in as a core capability inside the new Utility Network, which is the next generation Geometric Network.  It is no longer an extension, it is just part of the Utility Network.
Pro doc for network diagrams: http://pro.arcgis.com/en/pro-app/help/data/utility-network/about-network-diagrams.htm
RajeshMane3
Thanks Dan for routing this issue to Schematics Specialist. Rick. I Remember I used to communicate with Rick way back in 2010 for my Sch Issues.
Hi Rick,
I appreciate your valuable information provided to my query
But How following things can be migrated in new version Network diagrams component of UN
   1. Existing Configuration of Schematics which is on ArcGIS 9.3.1 (Older Standard and XML Builder)
   2. The diagrams which are built on existing 9.3.1 Sch Engine. Any idea of how to migrate those into Network diagrams.
Regards,
Rajesh Mane
