Scale Bar Errors in Layout
1084
08-07-2024 10:46 PM
stevebrooks1
I have recently noticed, had it brought to my attention, that there appears to be an issue when adding a scale bar to a layout.  the issue i am seeing is that numbers along the scale bar are repeating ie there will be 50, 100,100,200,200,200,300,300 (unfortunately  I cannot show an accurate example as it is on a different system.
Any ideas for a fix???
TomBole
Hi @stevebrooks1
I'm not aware of any specific issue regarding the duplication of scale bar labels. It would be extremely difficult to troubleshoot this issue without more information - scale of map, scale bar property settings, etc...
The problem you are running into may be specific to your data/workflow. Can you contact Esri Support? They are better equipped to handle troubleshooting steps and gather bug data. They can be contacted at https://support.esri.com/en/contact-tech-support.
Tom
