saving LYR file from arcgis pro
33822
7
06-08-2016 04:06 AM
SPNIOrganization
I made very nice symbology for a point layer in arcgis pro. I would like to share this symbology in a way that can be used also on arcmap.
The only option I found is to save a lyrx file but arcmap 10.4 does not recognize this file..
Is there any solution?
thank you,
Dikla.
Tags (3)
JohnSolly1
I ran into the same problem, but I found a workaround! Publish the layer in ArcGIS online from Pro and then pull the published layer into ArcMap by logging onto ArcGIS online from inside ArcMap. You can then save it as a .lyr file.
DanPatterson_Retired
Creates an output layer file (.lyrx) from a map layer. The layer file stores many properties of the input layer such as symbology, labeling, and custom pop-ups. Layer files saved from ArcGIS Pro cannot be used in ArcMap.
Save To Layer File—Data Management toolbox | ArcGIS for Desktop
JohnSolly1
EdCarter
I need to access the data in Enterprise not AGOL. I tried adding the enterprise address in the ArcGIS administrator and opening the portal in ArcMap but the connection fails. The error message says it was trying to access AGOL, but the button clearly was changed to portal.  Why can't ArcGIS Pro save to a .lyr file as an option instead of .lyrx? There is even a dropdown box for it. But the dropdown only lets you select from one choice. ! ??
CherylSannebeck1
Dan Patterson
I accidently changed the file path for a .lyrx to an Adobe Acrobat DC file vs the "Opens with: Windows Shell Common." How do I revert the .lyrx back to "Opens with: Windows Shell Common."
StephanieSnider
Right click on the file and select Properties.  On the General tab next to "Opens with", click the Change button.  Select or Browse to the application executable that you want the file to automatically open to.
CherylSannebeck1
Thank you so much!
KeithAddison1
I can't get the publish to AGOL work around to work.  Map just doesn't seem able to read what I publish using Pro.  Any other way to do this?
