Run Script Tool in batch mode
1806
05-23-2021 08:58 PM
CPoynter
I have created a python script which I am applying to a 'script tool'. I have configured the tool but wish to be able to run the tool in batch mode if possible, similar to other 'system tools'. The batch portion relates to input variables for the script to process.
DanPatterson
MVP Esteemed Contributor
So this goes beyond what a "Multivalue" parameter can deal with?
Setting script tool parameters—ArcGIS Pro | Documentation
... sort of retired...
CPoynter
Trying to achieve similar prompt when 'batching' other system tools, where you have each parameter laid out for inputs:
Param 1Param 2Param 3Param 4
Aa1A;B
Bb2C;D
Cc3E;F
Dd4G;H;I
So a list is created for each set of four parameters:
lst = [['A', 'a', '1', 'A;B'],['B', 'b', '2', 'C;D'],['C', 'c', '3', 'E;F'],['D', 'd', '4', 'G;H;I']]
Tool will be distributed, so unsure of inputs to create 'MultiValue' lists.
