Route event layer sometimes not refreshing on map
304
05-19-2026 10:44 AM
MRJ1
Hello,
I was just looking for a follow-up regarding the following documented bug in ArcGIS Pro:
BUG-000137329
https://support.esri.com/en-us/bug/the-edits-of-the-points-for-positions-in-route-event-la-bug-00013...
With my LRS datasets, I have been encountering issues with route event layer(s) sometimes not updating properly when the source attribute table is edited. The suggested workaround works well, but the underlying issue doesn't appear to have been addressed as of ArcGIS Pro 3.6.4. The bug report suggests it's under consideration. Are there any updates to provide?
ArcGIS Pro 3.6.4.
Thanks for your time.
Robert_LeClair
Esri Esteemed Contributor
@MRJ1 - in reviewing BUG-000137329 - "The edits of the points for positions in Route Event Layer in ArcGIS Pro are not displayed unless the cache settings are changed", it's listed as "under consideration" within the "internals" with the current workaround to "change the cache settings of the layer to any other option."  No time frame for a fix that I know of...
