Rounding issues using Python in ArcGIS Pro
11353
12
02-05-2018 08:38 AM
AdrianWelsh
MVP Honored Contributor
It seems to me that ArcGIS Pro is not rounding my numbers correctly when I use Python in Calculate Field. Or my expression is incorrect.
Here is my example:
The Shape_Area of a feature is 7464.72748
My Calculate Field expression is
str(int(round(round(!Shape_Area!), -1)))
I would think this should result in a string value of 7470, but it gave me 7460.
Where am I going wrong? Shouldn't round(7464.72748) give me 7465 more or less?
And then round(7465, -1) give me 7470?
MarcoBoeringa
Please also have a look at the "decimal" module of Python:
https://docs.python.org/3.6/library/decimal.html
It may offer functions you need as well. You can import the module in e.g. the Calculate Field tool.
AdrianWelsh
Rounding is ridiculous.
Joining up an "engineer's" spreadsheet with sorta-rounded-area numbers (integers) with a converted CAD drawing takes more effort than it should. This is what my code block Calculate Field expression had to look like to get as close as I could (though, I likely could have gotten closer with more ceilinging and flooring, but I got lazy):
import math
def ceiling(parcel, area):
    return str(parcel) + " - " + str(int(math.ceil(math.floor(area) / 10)) * 10)
__esri_field_calculator_splitter__
ceiling(!Parcel!, !Shape_Area!)
thanks, Dan, for all the assistance!
DanPatterson_Retired
engineers???  cool!   use the base 9 thing.. that will keep them going for a few hours
