rotate marker
1385
06-06-2023 07:49 AM
MarcelSt-Germain
Hi, I know you can individually make each symbol rotate with the rotation of the view.
In arcmap, we can do it once an for all by selecting the wright box.  I try to find the same function in Pro without success.  All info I found is for individuals symbols.  Where can I find the box to check to make my marker follows view rotation?
RhettZufelt
MVP Notable Contributor
Format symbol:
R_
MarcelSt-Germain
Like I said, this is known, but how for all symbol.  With hundred of them, on shot fit all is the way, like in arcmap.
RhettZufelt
Not sure if that is available in Pro.  In ArcMap, it was an all or nothing in advanced settings.
You can rotate ALL the symbols in a layer at once, but not sure if it is possible to do it for all layers as well.
To rotate all in a layer with the Map:
R_
MarcelSt-Germain
Unfortunately, I also think that ESRI again mist it.  By giving more flexibility, they lack simplicity.
When you work with hundred of markers, arcmap is a better way to fix rotation at once even if you pinpoint modification on some of them.
