I am reclassifying a integer field with the following code in field calculator:
Reclass(!Field!)
# Reclassify values to another value
# More calculator examples at esriurl.com/CalculatorExamples
def Reclass(arg):
if arg is None:
return None
elif arg <= 0:
return None
elif arg >= 1:
return 1
return arg
___________________________________________
For the last elif, I would like to return the original value being evaluated. What do I need to replace 1 with in order to get the original value?
If I remove 'elif arg >= 1 and return 1', all the fields return None. Probably real simple but cant seem to find solution on any of the forums.
