Reset layer symbology
2779
11-26-2022 11:32 PM
Bud
Legendary Contributor
In ArcGIS Pro 3.0.2:
Is there a way to reset a layer's symbology to get the default symbol settings?
Without removing and re-adding the layer, since I would lose my definition query, join, and other settings.
Thanks.
DanPatterson
MVP Esteemed Contributor
Apply Symbology From Layer (Data Management)—ArcGIS Pro | Documentation
but that means you need to have used
Save To Layer File (Data Management)—ArcGIS Pro | Documentation
first for layers with critical symbology.
Closing Pro with saving changes will 'reset' when restarted, but that is only useful for inadvertent and/or unretractable mishaps.
... sort of retired...
RhettZufelt
MVP Notable Contributor
Don't remove, just re-add the layer, then save as Layer file with the default symbology, remove added layer, apply original symbology from the layer file just created.
R_
