Repair many broken repair data source
14512
8
09-28-2020 09:34 AM
DEAF_PROBERT_68
Honored Contributor
When you received one or many layers that came to you from someone else or  from other sources and has many red exclamation point(s) next to each layer.
I followed the instructions that came with it but didn't get what I wanted.
Repair broken data sources in a map—ArcGIS Pro | Documentation
I was trying to get all of them to get their data sources click at once but I had to click each at a time instead.
Is there a way to do that ? or is that the only way to do that ?
Thanks
 Rebecca McKinley
Dan Patterson
Amber_Support
Esri Alum
Hello! I have found this ArcGIS Blog post that gives 5 tips when fixing broken links which you can find here: ArcGIS Pro Tips: 5 Tips For Fixing Broken Data Links
One tip states, "If you have several layers that reference the same data source, that need to be fixed, you can repair the links one time in the Contents pane and ArcGIS Pro automatically repairs other broken layers. For example, if you have several feature classes stored in the same geodatabase, and the geodatabase has been renamed. Click the red exclamation point next to the layer to open the Change Data Source dialog box and browse to the correct source."
MichaelVolz
Esteemed Contributor
What is the data source (SDE - SQL Server, Oracle, other, file gdb, shapefile, other)?
This has implications on how you can proceed, especially in terms of access to Oracle SDE database.
DEAF_PROBERT_68
Honored Contributor
They are shapefiles
MichaelVolz
So did all the shapefiles in your aprx project have a red exclamation point and do they all point to the same folder location?  I believe all the shapefiles would need to reside in 1 folder for your 1 click workflow to work.
DEAF_PROBERT_68
Honored Contributor
That is what I did. They all are in the same folder.
Amber_Support
Esri Alum
DEAF_PROBERT_68
Honored Contributor
Yes !!!!! that is so much better and it has the screenshot to show me how this works.....  it's a life saver !
Spatial_Fabio
From multiple SDE layer it doesn't work. I have to repair manually one by one
AdrianMarsden
Honored Contributor
indeed - another step backwards for the (still IMHO pre-beta) software that is ArcGIS Pro.
I do wonder how these decisions to remove features are made - old desktop had the perfectly good "Repair" option that, well , did the job, but that is now gone.
