Remove z values when creating a feature class
2255
10-01-2021 01:03 PM
LyonMNGIS
Hello,
Is there a way to change the default so that z values are disabled by default when creating a feature class?  When I right click and select New Feature Class the z values are enabled by default.  If possible I would like to change the default so that z values are disabled.  Interestingly I did notice that the Create Feature Class geoprocessing tool has Z values disabled by default.
Thank you for any help
DanPatterson
MVP Esteemed Contributor
I don't see one in Project backstage Options.
The best method is to use arctoolbox tools, since the Environments tab on each tool provides access to a variety of other controllable aspects of geoprocessing.  Shortcuts sometimes provide less options and control
... sort of retired...
