Remove text between brackets with arcade
1583
11-05-2021 10:16 AM
OM
Hello, I need to remove all html elements in text fields from popups in ArcGIS Pro/ArcGIS Enterprise.  Text fields could contain multiple instances of <>.
text field - Description
<p><span style="color: rgb(68, 68, 68);">this artwork was commissioned through the City's </span>Hogan Alley Artist Call 2019.&nbsp;<span style="color: rgb(68, 68, 68);">In February 2019, the City invited proposals for a temporary painted mural.&nbsp;</span></p>
Can't find a way to set this up with Arcade
OM
jcarlson
MVP Esteemed Contributor
It's not terribly elegant, but you can do this with a few nested loops and some splitting and searching.
var str = your-string-attribute
// Split input string by '>' char
var splits = Split(str, '>', -1, True)
// Empty string for output
var outstr = ''
// Iterate over split string
for (var s in splits){
    var substr = splits[s]
    // Find items not beginning w/ '<', i.e., not HTML tags
    if (Left(substr, 1) != '<'){
        // Check if string ends w/ HTML tag
        var i = Find('<', substr)
        // Trim HTML tag from end if present
        if (i != -1){
            substr = Left(substr, i)
        outstr += substr
outstr
And for the proof:
You'll notice the "&nbsp;" does not get removed, but we were only looking for HTML tags. These could easily be stripped out with a Replace function, though. Or rather than stripping them out, replacing them with '\n'.
- Josh Carlson
Kendall County GIS
jcarlson
var outstr = ''
        if (i != -1){
        outstr += substr
outstr
And for the proof:
- Josh Carlson
Kendall County GIS
OM
Can't thank you enough for solving this.  It worked great.
Olga
