Remove Service Layer Credits
94349
16
11-10-2016 02:56 PM
MeleKoneya
I would like to be able to remove the Base map Service Layer Credits.
I think it is confusing for the map user as it looks like it is the source for the data shown and not the base map
Is there a way to do this?
JoshWhite
Honored Contributor
Took me a minute, but I figured it out.  I have no issues with having the credits on the layout, what I have an issue with is how long they are.  Instead of:
Sources: Esri, HERE, Garmin, Intermap, increment P Corp., GEBCO, USGS, FAO, NPS, NRCAN, GeoBase, IGN, Kadaster NL, Ordnance Survey, Esri Japan, METI, Esri China (Hong Kong), swisstopo, OpenStreetmap contributors, and the GIS User community
Why can't it be ?
Source: (c) 2019 Esri and business partners
Many of the other sources in this list are not worldwide.  For instance, in the US, Esri Japan and Esri China and Kadaster NL (among others) have no content here, so why list them?  I realize this is called the World Topographic map but surely you see my issue.
Josh White, AICP
Principal Planner
City of Arkansas City
JeffBarrette
Thanks Josh.  Software development is aware of your concerns.  There is an existing enhancement request that we hope to address as soon as possible.  If you are interested in tracking via customer support, the number is: ENH-000098885.
Jeff
KoryKramer
Esri Community Moderator
https://community.esri.com/ideas/16121 is fixed in ArcGIS Pro 2.6, scheduled for release in late July.
DavidForbuss1
Totally agree.  It just makes my layout looks messy.  I know people want their credit, but its really annoying having it somewhat forced into the map.  I've actually taken to to making my bottom rectangle overrun the map frame to cover them up.
Fahad
Thanks Jeff for great help,
It saved my tricky map...!
jhdn490
Thank You for that.   I was looking for a while.   It took your specific instructions for me to move the credits off the map.
JamiePearlstein
You can turn off the visibility of the service credits by doing the following:
While you are in the layout, click on the Insert tab, then go to Dynamic Text and select Service Layer Credits. In any area of the layout, create a small rectangle with the crosshairs. Now the service layer credits within this triangle has become a text box listed in the Contents pane and you can de-select it so it doesn't appear on the layout.
