Remove Non-numeric Characters
7324
05-06-2024 09:12 AM
FlightDeck
Hey all,
Looking for a simple way to remove any alphabetical characters from a field leaving only 1-9 and "-". Decimals shouldn't be an issue. Preferably python or arcade expression. Unfortunately Through searching I am unable to find a viable route to accomplish this task though the inverse is readily available. Any help is appreciated.
RhettZufelt
MVP Notable Contributor
Depending on the data, one way without using regular expressions. would be to iterate over the string, and if the values match your 'keeplist', then join them to new string, then split that string into the list.
instring = 'your99number/textvaluses-4testing'
keeplist = '0123456789.-'
numList = [i for i in (''.join((num if num in keeplist else ' ') for num in instring)).split()]
R_
CodyPatterson
MVP Regular Contributor
Hey @FlightDeck
If you would like to use regular expression, you can use this:
import re
def remove_alpha(value):
    return re.sub('[^0-9\-]', '', str(value))
While using it in this setup here:
Hope that helps!
Cody
JoshuaBixby
MVP Esteemed Contributor
I am a big fan of regular expressions, which is why I am so disappointed the Python builtin re module has such weak support for Unicode categories.  Fortunately, it is quite common that people will bundle regex · PyPI with their Python deployments, including Esri.
Using regex instead of re allows for people to use Unicode categories to write regular expressions that are much more portable in this global world we live in:
import regex
    return regex.sub("[^\p{NUMBER}\p{DASH}]", "", str(value))
