Remove all overlapping polygons
2553
05-30-2024 11:06 AM
Labels (2)
IanLadd_Tourmaline
I have a large layer with land polygons, there are some that are overlapping others, essentially what I would like is to remove all the overlapping ones so I have a flat layer that only shows 1 polygon per parcel, not multiple. You can see below, there are certain polygons that are only half the size of the ones below as well. Some touch others so I can't use the merge tool because it will create one large polygon. I just need to remove all the overlap, but that tool doesn't work as it removes the overlapping area, not the overlapping feature itself.
Ed_
by MVP Regular Contributor
May be try the "Erase" tool?
May be try select by location "Intersection" and then delete that selection of polys?
Question | Analyze | Visualize
DanPatterson
Tricky, but
Polygon Neighbors (Analysis)—ArcGIS Pro | Documentation
will get your close, look at the following to interpret the results to decide which polygons need to be removed, for the overlap case
How Polygon Neighbors Works—ArcGIS Pro | Documentation
... sort of retired...
