refresh
1072
10-18-2019 08:18 AM
BennyWhite
ArcGIS Pro (2.4.2) Add Data Refresh
I have a project that involves about 30 layers in the map.  I use a lot of Joins to Add Data.  Most of this is included in Excel workbooks with numerous tabs.
I find that when I add a tab to a workbook while Pro is open and then attempt to do a join on the data in the new tab, Refresh will not work to locate the new tab.
The only way I can access the new tab is to Save the Project, Exit the application and then reopen Pro.  The next time I Add Data there is a refresh cycle initiated and I can see the new tab.
I may be doing something wrong but it seems to me that the Refresh icon at the right side of the Explorer or Address bar is not functioning.  I would like to report this as a defect but I don't see an easy way to do that.
