Refine interior Orientation question ?
1633
03-12-2020 07:40 AM
DEAF_PROBERT_68
Honored Contributor
I have a question for those who have went through OrthoMapping
I have read this but I may have miss something...
Refine interior orientation using fiducials—ArcGIS Pro | Documentation
What if I wanted to use this to fiducial markers to my aerial photos and can I save it as a table and use it to another software without having to use it ?
I have a lot of scanned aerial photos that are old and have no information that I need to orthorecifiy them... They are in the 1938's
Is that possible ?
ChrisHuang8
Yes, you can. The tool will generate a fiducial marker table which records image space to film space links per fiducial. You could continue to execute block adjustment in orthomapping  or free to use in other software (you may need to do some conversion work).
DEAF_PROBERT_68
Honored Contributor
Ok so what if you have image that has no information but you need to input the latitude and longitude for each point on the image that has the fiducial markers I think there are 4 for each image ? Would that work ?
ChrisHuang8
Some prepare work is needed:
- per image: You only need to provide a center point (x, y, z) per image. Besides this
- per camera: focal length (micron), principle point(micron) scanned pixel size (micron), fiducial film coordinates from camera report
You may find more detail in Create an ortho mapping workspace for scanned aerial imagery—ArcGIS Pro | Documentation
