Records not showing in layer's table
1893
04-29-2025 07:25 AM
RachelK
I have a point layer with roughly 2M records. When I open the layer's table, there's no data, but when I select by attribute, the selected records display all the data.
Here's what the table looks when I open it up (kindly forgive me for having to redact it):
And here's what I see when I make a selection:
Why am I not seeing all the records at once? Here's a bit more info:
  • I'm using 3.2
  • I'm appending data to a "master" layer
    • I used to be able to see data for the first 400k records
    • now I don't see any data unless I make a selection
  • when I summarize within, no data is carried over into the polygon layer
Any help is appreciated!
MikeVolz
Just as a test, what would happen if you exported the 2 million records to a new feature class in a new file gdb?
How long has this layer been in use with this append process?
RachelK
It worked! I created the layer last week and will be adding to it this week and next, bringing the total to around 3M.
Thanks!
Robert_LeClair
Esri Esteemed Contributor
In your graphic of the records selected in the attribute table, lower left, you have the Show Selected Records button selected.  Click the button to the left of that for Show All Records.  Then you'll see all records selected or not.
RachelK
Thanks for this suggestion! It worked and now all records are showing.
Robert_LeClair
GREAT!  If you feel one (or both) of our answers are correct, please click the "Accept as Solution" button next the response to close out this thread.  Have a great weekend!
