reclassify tool bug in ArcGIS pro 3.2.1
1308
01-26-2024 01:10 PM
StevenRoss2
I am trying to reclassify an integer raster using ArcGIS Pro 3.2.1. I need to increase the number of classes to 10 and use quantile based classification. When I press the classify button it opens the window to change number of classes and method of classification but I am unable to change either of these fields - it is stuck on METHOD = Natural breaks (jenks) and CLASSES =  5. I was able to do the reclassify the raster in ArcMap 10.3 so I know this can be done and the raster works but am trying to transfer over to ARcMap Pro.
Is this a bug and will it be fixed. Are other people having this same issue?
DanPatterson
MVP Esteemed Contributor
BUG-000161097 for ArcGIS Pro (esri.com)
BUG-000158421 for ArcGIS Pro (esri.com)
plus others that might be the case if you can narrow down the workflow
Esri Support Search Results
... sort of retired...
