Reclass no data using reclassify tool
3371
04-25-2023 04:40 PM
hkmuaf
Hi Everyone, I’m new to the community and apologize if this thread already exists and I just didn’t find it. I am needing to reclassify no data values from no data to 0. This is simple in ArcMap with reclassify tool, but it is not letting me do it in Pro. I can change the value but when I click off the value pane or start running the tool it automatically returns to a value of no data in the reclassify table. Any help appreciated!
DanPatterson
MVP Esteemed Contributor
MeganWalmsley
I realize this thread is 3 years old, but I was having this same problem this week and was finally able to figure it out. Adding my experience with this problem here in case someone else has the same problem and comes across your post in the future.
Issue: When reclassifying data in ModelBuilder, I was not able to edit the final value in the "new" column from "NoData" to "10". It would revert back to the previous value as soon as I clicked out of the value box or ran the tool, the same as the original post.
Solution: press enter after inputting the final "new" value. That's it. Clicking out of the value table caused the final value to revert every time, but not if you press enter. The previous values were saved because I was clicking out of their new value boxes into the next new value box, but since I would just click somewhere outside of the table after entering the final new value, it wasn't saving it.
