Rasters and AGOL
1631
01-04-2023 07:25 AM
JohnHindle7
I have created several mosaic rasters and experimented with different workflows to get them on AGOL with success. The most recent is using both hosted tile imagery and dynamic tile imagery.
The issue I'm running into is that whenever I upload my raster datasets to AGOL, I lose my attributes that go along with it. I'm specifically trying to retain a floor height attribute, and see no where on AGOL where I can add fields, all I get is Pixel value fields.
Any suggestions?
TarenW
Hi @JohnHindle7
Have you tried the workflow outlined here
JohnHindle7
No I haven't. I'll take a look and experiment and let you know if it works. Thanks.
JohnHindle7
So I've tried that solution, but the issue is that the "Build Raster Attribute Table" tool doesn't support mosaic datasets. It also only supports single band rasters, which is fine, as I only need table data, not pixel data.
LanceCole
@JohnHindle7 ,
Are you just using ArcGIS Online or are you using ArcGIS Image for ArcGIS Online?
It is my understanding ArcGIS Online can only host mosaic imagery for visualization as a tiled map service. ArcGIS Image for ArcGIS Online is required to expose the underlying data for analysis from a mosaic dataset as an image service.
JohnHindle7
I've tried both ArcGIS Image as well as using the tool in ArcGIS Pro
