Raster resampling when Clipped - why? How to prevent?
2508
11-13-2025 01:21 PM
JasperRomero
Same question as a previous post of mine - still no solution so trying again with more information and examples.
As part of a georeferencing workflow, I run the Clip Raster tool to remove non-image edge regions. However when I run the tool, the resulting image is resampled and has a different cell value histogram. I am less concerned about the histogram change - I will be color balancing in a mosaic dataset later on - but I want to understand why the cells appear to be resampled.
Input RasterInput RasterOutput RasterOutput Raster
Both the size and shape of the cells in the image appear to change. When I check the cell size in the raster Properties, it states that the cells are the same size - but the Clipped image has a visibly coarser resolution that persists when the image is georeferenced and saved.
Juxtaposition of input (top) and output (bottom) along Clip boundaryJuxtaposition of input (top) and output (bottom) along Clip boundary
I run the Clip Raster geoprocessing tool with a drawn polygon as the output extent, "Use Input Features for Clipping Geometry" checked, and the default values for No Data and Maintain Clipping Extent (256 and Unchecked, respectively). I have tried setting the Input Raster as the Snap Raster but this doesn't appear to help.
I am fairly sure that this behavior did not always occur, as I documented the workflow in the spring and specifically used the steps and order that I did to avoid visible resampling of the input.
Does anyone know why this is happening, and how I can prevent it? It is very frustrating. Thanks in advance for any assistance!
Editing to add - Pro version 3.4.3
CalvinHarmin
MVP
Sorry if this is a dumb question since you seem to know what you're doing - but are you certain both layers have STRETCH settings turned off? I think Pro tends to default to applying stretch settings to new rasters added to the map - although this default is something you can change if I'm not mistaken.
If you use the navigation / query / pop-up info tool to poke a cell and see its value - are the cell values ACTUALLY different between the input and output rasters when you inspect a specific cell?
'Snap raster' option being set to the source raster should be used as part of your process if you want to ensure the cells don't get resampled or offset from original - but that's just one aspect and not the whole answer.
CalvinHarmin
MVP
Following up after testing on my end - here's what I would do:
Clip Raster
  • Use your polygon as output extent
  • Do not change the default (unchecked) options for clipping unless you are wanting on odd shape - maybe test that after following these other steps to see if the output differs.
  • Environments:
    • choose the source layer as the output coordinate system, if your map's coordinate system differs
    • Snap Raster - choose your source layer
    • Do not build Pyramids or calculate statistics - the resampling method by default is 'Nearest' but that only relevant for calculating pyramids so it doesn't matter.
Your output will apparently look different from the source. To compare apples to apples, open the Symbology tab for each respectively and change Stretch Type to None, Gamma to 1.0 (or whatever as long as its the same), and set the Statistics as Custom: 0 min and 255 max.
JasperRomero
@CalvinHarmin thanks for your efforts here - sorry this slipped through the cracks for me. Appreciate the suggestion about checking Stretch settings, that had not occurred to me. The pixel values were indeed being resampled, though that was not too much of an issue because of the downstream color balancing.
Re: the cell size resampling - I wound up avoiding that behavior using the following process (not sure why this made the difference, seems like it shouldn't have - if anyone knows why, would love an explanation):
Rather than using Clip Raster on the original raster image, I georeferenced a single point in the image to put the tile in roughly the right place, then used Save as New from the Georeferencing tool bar. Using the Clip Raster tool on the newly saved copy created a clipped raster without resampled pixel sizes. Not sure why this was necessary, but it worked. Was also experiencing behaviors described here sometimes, so maybe was just having bad luck with bugs.
