Raster Clip - Clipping Type
2285
6
10-30-2019 01:06 PM
LeifJohnson3
Why can't I choose to clip outside or inside the "output extent" and is there another way to do this if you can't?
Tags (1)
KoryKramer
Esri Community Moderator
Have you looked at the Clip raster function: Clip function—ArcGIS Pro | ArcGIS Desktop
LeifJohnson3
Thanks for the reply Kory.  I'm trying to remember where I left off with this because I did know about the Raster Functions toolset.  I think the problem I was having is that I was trying to create a model that would do this for me to a bunch of different rasters and it appears that I'm not allowed to use raster functions in model builder.
MichaelVolz
Esteemed Contributor
Can you try to export this out to python and see if the raster functions can be added in the python environment?
KoryKramer
Raster functions aren't something that I work with much, but I found this which might help in scripting: Generate Raster From Raster Function—Data Management toolbox | ArcGIS Desktop
LeifJohnson3
That looks like it could be exactly what I need.  Thanks Kory!
EricSamson1
Hi Leif,
Did you ever get this working? I couldn't get it to run, I keep getting parameter errors. Could you potentially share a code snippet of your working solution? Thanks!
