raster cell orientation?
2355
02-22-2017 02:52 PM
jadenrowley
I am creating 20 km raster cells around earthquake points in arc desktop 10.1. Using a conic projection, I would like the cells to  cells to line up with true north rather than the edges of my layout. Is there a way to do this? I tried creating the rasters in a different projection (create in wgs84 and project in albers equal area conic did the trick, but with the wrong size) but have found no solutions yet for rotating individual rasters around their centroid.
DanPatterson_Retired
The raster cells will always be axis oriented I suspect regardless of rotation, but you can give it a try using the following.,  I don't have a coarse raster to test with
jadenrowley
I tried rotating the dataframe, but the rasters still align with the original position. I think for now I will use a different projection so that it lines up when reprojected to albers (distorts area but rotates proper).
