Raster calculator and Con statement
3398
03-15-2023 07:18 PM
JasmineSpring
Hello
I am having troubles building my expression in raster calculator
I am trying to work around not being able to use decimals in reclassification. I am multiplying multiple rasters, If the values is 1, Id like it to stay a 1 and all other values be divided by 100 before I multiply them. After mutliply the rasters I want to take the value from 1.
1 - (Con("Grid1" = 1 ,1 , "Grid1" /100 )* Con("Grid2 " = 1 ,1,"Grid2" /100))
Hope that makes sense
Thank you!!
Jasmine
Luke_Pinner
MVP Regular Contributor
Try explicitly using decimals
1.0 - (Con("Grid1" == 1, 1.0, "Grid1" / 100.0 ) * Con("Grid2 " == 1, 1.0, "Grid2" / 100.0))
Or possibly using the Float function:
1.0 - (Con("Grid1" == 1, 1.0, Float("Grid1") / 100.0 ) * Con("Grid2 " == 1, 1.0, Float("Grid2") / 100.0))
Luke_Pinner
The equals operator is "==" not "=".
So you should use:
1 - (Con("Grid1" == 1, 1 , "Grid1" / 100 ) * Con("Grid2 " == 1, 1, "Grid2" / 100))
A worked example assuming Grid1 == 1 and Grid2 == 2
expression evaluates to: 1 - 1 * 0.02
output: 0.98
JasmineSpring
Thank you for your help!
Unfortunately it didnt work, it just gave one value in the resulting raster
yes that is the resulting equation im after !
for example
1 - (1*0.2*0.8*1*0.4) = 0.936
but what I have is integers
1- (1 *20 * 80 * 1 *40)
so if the value is a 1, Id like to keep it as a 1 and if its higher than 1 Id like to divide it by 100 to make it a decimal.
Thank you!
Luke_Pinner
JasmineSpring
worked perfectly!! thank you so much
